title: "How to use FusionDSP plugin?"
description: ""
url: https://help.volumio.com/en/articles/99-how-to-use-fusiondsp-plugin
collection: "FAQ"
updated: 2026-11-07
language: en
# How to use FusionDSP plugin?
FusionDSP plugin is an high-quality DSP downloadable from Volumio PLUGIN STORE.
It works on the internal audio stream, such local files, streaming services playback or webradios.
## How to set graphic equalizer?
1.  Choose your equalizer mode
2.  Set values you want
3.  Click apply
## How to equalize headphones?
FusionDSP is able to import Headphone equalizer settings directly from Autoeq:
-   Set the mode on Parametric Eq
-   Scroll down to the section
-   "Import EQ from Autoeq"
-   Choose your headphone model in the list (it may take several second before it appears)
-   Click "Import and load EQ"
It's done! You can see values loaded. For your headphone, you can use a Crossfeed.
FusionDsp provides 7 different Crossfeed:
-   Click on "More settings"
-   Choose the Crossfeed you want.
-   Click on "Apply"
## How to use custom presets?
In FusionDSP, all settings can be saved in 5 custom presets:
-   Move to "save current settings" section
-   Choose in which preset you want to save settings.
-   You can rename the preset as you like
-   Then press "apply"
Now the new preset can be used. Before, let's first reset settings to see that:
-   Go to the section "Use preset"
-   Choose the one you created
-   Press "Load and use"
