How to use FusionDSP plugin?
FusionDSP plugin is an high-quality DSP downloadable from Volumio PLUGIN STORE.
It works on the internal audio stream, such local files, streaming services playback or webradios.
How to set graphic equalizer?
  1. Choose your equalizer mode
  2. Set values you want
  3. Click apply
How to equalize headphones?
FusionDSP is able to import Headphone equalizer settings directly from Autoeq:
  • Set the mode on Parametric Eq
  • Scroll down to the section
  • "Import EQ from Autoeq"
  • Choose your headphone model in the list (it may take several second before it appears)
  • Click "Import and load EQ"
It's done! You can see values loaded. For your headphone, you can use a Crossfeed.
FusionDsp provides 7 different Crossfeed:
  • Click on "More settings"
  • Choose the Crossfeed you want.
  • Click on "Apply"
How to use custom presets?
In FusionDSP, all settings can be saved in 5 custom presets:
  • Move to "save current settings" section
  • Choose in which preset you want to save settings.
  • You can rename the preset as you like
  • Then press "apply"
Now the new preset can be used. Before, let's first reset settings to see that:
  • Go to the section "Use preset"
  • Choose the one you created
  • Press "Load and use"
