title: "How to setup Multiroom in the better way?"
description: ""
url: https://help.volumio.com/en/articles/87-how-to-setup-multiroom-in-the-better-way
collection: "FAQ"
updated: 2026-04-13
language: en
# How to setup Multiroom in the better way?
To do before:
-   We suggest the ethernet cable connection, at least from the Master group device to the router (if it’s not possible use the 5GHz network as preference)
To do next:
-   Click on the MULTIROOM icon on the top right corner of the User Interface
-   Click on GROUP DEVICES
-   Click on ADD to add the selected device to the group
Your music is not perfectly synchronized?
Go to the Multiroom client User interface: SOURCES → MULTIROOM → SETTINGS
-   Increase the hardware latency in msec unit, this will delay all the other devices, in the same multiroom group, among the selected client device
-   Adjust the buffer size in msec unit (in case your hardware/network connection is not performant). This will delay all the client devices
> **Info:** No master group volume control available; it's not possible to create group between devices on different networks.
