First make sure the SMB protocol is enabled on the NAS settings. Then on the Volumio interface browse to SETTINGS → SOURCES → NETWORK DRIVES → click on SCAN.
If you are not able to find the unit, insert manually the requested infos (IP/shared path/name of NAS (alias)/CIFS or NFS protocol).
