title: "Which is the best Wi-Fi network connection to select?"
description: ""
url: https://help.volumio.com/en/articles/83-which-is-the-best-wi-fi-network-connection-to-select
collection: "FAQ"
updated: 2026-11-01
language: en
# Which is the best Wi-Fi network connection to select?
2.4 GHz network is the most common used, its signal coverage is better distributed on horizontal line floor and it could be easily extended/amped using proper network tools.
5 GHz network has less signal coverage than 2.4 GHz one, but it’s suggested for high data traffic (hi-quality audio stream). It works well only if the 5 GHz unit is near to the router (suggested in particular for the wireless devices of Multiroom groups).
