title: "How to select mixer output?"
description: ""
url: https://help.volumio.com/en/articles/79-how-to-select-mixer-output
collection: "FAQ"
updated: 2026-11-09
language: en
# How to select mixer output?
Volumio allows to select the best mixer preference according to your audio chain.
First:
-   Go to SETTINGS menu
-   Go to PLAYBACK OPTIONS menu
Here, you have 3 mixer choices:
-   Software: mixer algorithm is demanded to Volumio OS
-   Hardware: mixer algorithm is demanded to the streamer board (suggested if you are using Volumio Primo without external DAC)
-   None: mixer algorithm is demanded to an external DAC/AMP
> **Info:** Note: on Volumio devices where the volume is managed by the device itself (such as Primo), the Mixer Type option isn't shown. To get a fixed output, set the volume to 100 and control it from your amplifier.
