title: "TIDAL tracks showing as 16 bit instead of 24 bit in Volumio"
description: ""
url: https://help.volumio.com/en/articles/56-tidal-tracks-showing-as-16-bit-instead-of-24-bit-in-volumio
collection: "Issues & solutions"
updated: 2026-10-26
language: en
# TIDAL tracks showing as 16 bit instead of 24 bit in Volumio
If music streamed from TIDAL appears as 16-bit in Volumio even when you expect 24-bit / Hi-Res audio, the issue may be related to the TIDAL streaming quality setting.
In some cases, selecting Highest Rate does not provide the expected 24-bit Hi-Res stream.
Solution:
1.  Open Settings → Sources → TIDAL in Volumio
2.  Locate the Streaming Quality option
3.  Set the quality to Hi-Res instead of Highest Rate
4.  Restart playback and check the track information again
After setting the quality to Hi-Res, compatible tracks should be streamed in 24-bit resolution
> **Info:** Not all albums on TIDAL are available in Hi-Res format, even if different versions of the album exist. If a track is only available in standard or CD quality, it will still be streamed at 16-bit.
