title: "How to connect a Denafrips DAC to Volumio Rivo+ via I2S"
description: ""
url: https://help.volumio.com/en/articles/55-how-to-connect-a-denafrips-dac-to-volumio-rivo-via-i2s
collection: "FAQ"
updated: 2026-10-20
language: en
# How to connect a Denafrips DAC to Volumio Rivo+ via I2S
### Step 1: Connect the Hardware
1.  Power off both Rivo+ and the Denafrips DAC
2.  Connect the I2S (HDMI) output of Rivo+ to the I2S input of the Denafrips DAC
3.  Power on the DAC first, then the Rivo+
### Step 2: Set the Correct I2S Configuration on the Denafrips DAC
By default, Denafrips DACs may not use the correct I2S pin layout for Rivo+, which can cause:
-   Very distorted or screeching sound
-   Audio that sounds “broken”
-   Incorrect left/right channel playback
To fix this, you must change the DAC I2S mode.
Required setting:
-   I2S Mode: 5
-   LED sequence: 1 - 0 - 1
This aligns the DATA, BCK, and LRCK signals correctly with Rivo+.
### Step 3: How to Change the I2S Mode
Follow the official Denafrips instructions here:
[https://www.denafrips.com/config-pontus](https://www.denafrips.com/config-pontus)
After setting Mode 5:
-   Restart the Denafrips DAC
-   Restart the Rivo+
### Step 4: Select Output in Volumio
1.  Open Volumio UI
2.  Go to Settings → Playback Options
3.  Select I2S / HDMI output
4.  Start playback
### Important Notes
-   This applies only when using I2S
-   USB and S/PDIF connections do not require this configuration
-   This is not a fault of Rivo+ or the DAC
-   Once set, no further changes are needed
### Summary
If a Denafrips DAC sounds distorted when connected to Rivo+ via I2S:
-   Set the DAC to I2S Mode 5
-   Confirm LED sequence = 1 - 0 - 1
-   Restart both devices
This ensures full compatibility and correct sound reproduction.
