title: "Fixing NFS connection issues with Synology after Volumio update"
description: ""
url: https://help.volumio.com/en/articles/49-fixing-nfs-connection-issues-with-synology-after-volumio-update
collection: "Issues & solutions"
updated: 2026-08-18
language: en
# Fixing NFS connection issues with Synology after Volumio update
If your Synology NFS share stops working with Volumio after an update, follow these steps:
1.  Check if the IP Address Changed: Verify whether your Volumio device has a new IP address. If so, update the NFS permissions on your Synology to match the new IP.
2.  Update Permissions in Synology: In the Synology DSM UI, go to the shared folder settings. Under NFS Permissions, update the allowed IP address to the new one from Volumio.
3.  Configure NFS Options in Volumio: Go to Sources → Add New Drive in the Volumio UI.
4.  When entering mount options, use `vers=3`
5.  Save the configuration
6.  Rebuild the Music Library
Once mounted, Volumio will begin building the music database from your Synology drive.
