Maximum size for microSD card and external SSD
Micro SD Card: Volumio supports Micro SD cards up to 2TB, provided they are formatted correctly. We recommend FAT32 formatting for optimal compatibility.
External SSD Drives: There is no strict size limit for External SSDs. However, compatibility can depend on the drive's format. For best results, use EXFAT, FAT32, or NTFS formatting.
