title: "CD ripping not working"
description: ""
url: https://help.volumio.com/en/articles/44-cd-ripping-not-working
collection: "Issues & solutions"
updated: 2026-07-20
language: en
# CD ripping not working
If you are experiencing issues with CD ripping, please try the following steps to resolve the problem:
1.  **Use a Powered USB Hub**: Connect your CD drive to a powered USB hub. Sometimes, the CD drive may not receive sufficient power from your device’s USB port, which can cause issues with the ripping process.
2.  **Check Power Supply**: Ensure that the CD drive is properly connected and receiving enough power. Insufficient power can prevent the CD drive from functioning correctly during ripping.
3.  **Verify Connections**: Make sure all cables are securely connected to both the CD drive and the powered USB hub.
4.  **Restart Your Device**: Sometimes, restarting your device can help resolve connectivity issues with the CD drive.
5.  **Update Software**: Ensure that you have the latest version of the Volumio software. Updates often include fixes and improvements that can resolve hardware compatibility issues.
6.  **Try a Different USB Port**: If you are not using a powered USB hub, try connecting the CD drive to a different USB port on your device.
