title: "How to enable extra WIFI channels?"
description: ""
url: https://help.volumio.com/en/articles/35-how-to-enable-extra-wifi-channels
collection: "FAQ"
updated: 2026-08-20
language: en
# How to enable extra WIFI channels?
ONLY FOR DEVS AND TECH SAVVY:
If Volumio's wireless network scan does not return your network and your network wireless network is on channels 11,12 or 13 it is necessary to enable those extra channels (if allowed by your country legislation).
To do so:
1.  Enable SSH
2.  Connect to Volumio via SSH
3.  Username: volumio, Password: Volumio
4.  Type: sudo su
5.  Enter Password: volumio
6.  Type: echo "REGDOMAIN=IT" > /etc/default/crda Where IT is your country code. See this list to get your country code: [https://www.iban.com/country-codes](https://www.iban.com/country-codes) (You need the Alpha-2 Code)
7.  Type sync && reboot Optionally: if you want to verify that your country has been set properly, do all steps before step 6 and type: `sudo iw reg get` Password: `volumio` You should see: global country IT: DFS-ETSI (2402 - 2482 @ 40), (N/A, 20), (N/A) (5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW (5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS (57000 - 66000 @ 2160), (N/A, 40), (N/A)
If you can see your country properly selected, the setting has been applied successfully.
