How to switch Update Channel (Stable/Test)
You can receive beta (test) releases by switching the update channel to Test.
  • Open the Dev page of your Volumio device:
    • Type the local IP / address in your browser and add /dev at the end (i.e: volumio.local/dev OR 192.168.x.x/dev)
  • In the Update Channel Selection section, use the dropdown to select:
    • Test → to receive beta/test updates
    • Stable → to receive official stable updates
    • Go back to the main Volumio UI.
  • You are now ready to download beta test updates from SYSTEM MENU
Note: If you don’t want automatic beta builds anymore, go back to /dev and switch the channel to Stable.
