title: "How to install Volumio on x86/x64 based PC?"
description: ""
url: https://help.volumio.com/en/articles/24-how-to-install-volumio-on-x86x64-based-pc
collection: "FAQ"
updated: 2026-11-06
language: en
# How to install Volumio on x86/x64 based PC?
The installation steps for PC based systems are different compared to other platforms (RPI, Tinkerboard).
Follow these steps to install Volumio on your PC.
Remember that Volumio is a stand-alone OS, all the HDD contents will be overwritten.
-   Flash the x86/x64 IMG, you find [here](https://volumio.com/en/get-started/), on a USB KEY using Balena Etcher software
-   Insert the USB KEY in the USB port of the PC
-   Boot the PC from the USB KEY
-   It will start the Volumio First Config Wizard
-   Once done, Go to SETTINGS → SYSTEM → INSTALL TO DISK, you will transfer the OS from the USB KEY to the internal HDD
-   From now everytime you boot the PC from the default unit, Volumio will start as first OS
Please note: it is possible to boot Volumio everytime from USB KEY, but the performances will substantially decrease.
