title: "Music library issues"
description: "What to do when your music library is empty, incomplete or slow, or search doesn't find your music."
url: https://help.volumio.com/en/articles/199-music-library-issues
collection: "Troubleshooting"
updated: 2026-11-13
language: en
# Music library issues
Your music library is the music on USB drives, network drives and the device's internal memory. Its settings are in your device's `Settings` → `Sources`, under `My music`.
## Update or rescan
When music is missing, start here:
-   `Update library` adds the new files and removes the deleted ones. It's quick: use it first.
-   `Rescan library` reads the whole library again from scratch. It can take a long time with big libraries: use it only if `Update library` doesn't help.
While the device reads your music, `Scanning library…` shows at the top of your page. Wait until it disappears.
## The network drive is added, but there's no music
1.  Go to `Settings` → `Sources` → `Network drives` and check that the drive shows up under the mounted drives.
2.  Press the edit button next to the drive and check `Path`: it must point to the folder that holds your music, as shared by your NAS or computer.
3.  Check `File share type` and, if your NAS needs them, `Username` and `Password`.
4.  Press `Save drive`, then go back to `My music` and press `Update library`.
> **Tip:** If your NAS shows up under `Found on your network`, use that entry: it fills in the address and the path for you.
## Some music is missing from Artists or Albums
`Artists` and `Albums` are built from the files' tags (artist, album). Music without these tags doesn't show up there, but it's still in `Music Library`, which lists your folders.
1.  Go to `Browse` → `Music Library` and check that the music is in its folder.
2.  If it is, add the missing tags with a tag editor on your computer.
3.  Go to `Settings` → `Sources` → `My music` and press `Update library`.
## Music disappears after a restart
If your music is on a network drive, the device may have started before the drive was ready.
1.  Check that your NAS or computer is on and isn't asleep.
2.  Go to `Settings` → `Sources` → `My music` and press `Update library`.
If your music is on a USB drive, unplug it and plug it in again, then press `Update library`.
## The device is slow or stops responding with a big library
The first scan of a big library can take a long time, and the device can be slow while it runs.
1.  Wait until `Scanning library…` disappears from `Browse` before you use the device.
2.  If the drive is on the network, connect the device with an Ethernet cable.
3.  Don't press `Rescan library` unless you need it: `Update library` only reads what changed.
## Search doesn't find music that's in the library
1.  Go to `Settings` → `Sources` → `My music` and press `Update library`.
2.  Check the file's tags (artist, album, title) with a tag editor on your computer: search uses the tags, not the file names.
## Still not working
[Report a bug](https://help.volumio.com/articles/33-report-a-bug) from the app and tell us where your music is (USB, network drive or internal memory), roughly how many tracks it holds and, for a network drive, your NAS brand and model.
## Related
- [Report a bug](https://help.volumio.com/en/articles/33-report-a-bug.md)
- [Connection issues](https://help.volumio.com/en/articles/197-connection-issues.md)
- [Playback issues](https://help.volumio.com/en/articles/198-playback-issues.md)
- [Streaming service issues](https://help.volumio.com/en/articles/200-streaming-service-issues.md)
- [Startup issues](https://help.volumio.com/en/articles/201-startup-issues.md)
