Every Volumio product is designed and made in Florence, includes all Volumio Premium features at no additional cost (TIDAL, Qobuz, Spotify Connect, multiroom and much more) and is Roon Ready. Here's how to find the one that fits your system.
Choose a streaming DAC from the Primo family, which connects to your amplifier or active speakers with balanced XLR or RCA outputs:
Primo: the award-winning streamer that started it all.
Primo V3: the new generation, with higher resolution, NOS mode and adjustable outputs.
Primo Plus: our most advanced streamer (EISA Best Streamer 2026-2027), with dual mono DACs, extra digital inputs and remote control included. It controls the volume itself, so it can also connect directly to a power amplifier.
Choose a pure digital streamer, which sends the cleanest possible digital signal to your DAC:
Rivo: EISA Best Digital Player 2023-2024, with USB, S/PDIF and AES/EBU outputs.
Rivo+: adds I2S over HDMI, a dedicated ASIC for even cleaner S/PDIF and AES/EBU outputs, upgraded clocks and a 12V trigger.
Combine Rivo+ with Preciso, our dual mono high-precision DAC, connected via I2S, then connect Preciso to your amplifier or active speakers.
Lineo5 and Lineo5 Duo: low-noise linear power supplies for more detail and dynamics. The Duo powers two devices, such as Rivo+ and Preciso.
Remoto: the aluminum infrared remote for Preciso, to control volume, inputs, playback and DAC filters.
