title: "What's the difference between Lineo5 and Lineo5 Duo?"
description: ""
url: https://help.volumio.com/en/articles/160-what-s-the-difference-between-lineo5-and-lineo5-duo
collection: "FAQ"
updated: 2026-11-07
language: en
# What's the difference between Lineo5 and Lineo5 Duo?
Lineo5 and Lineo5 Duo are low-noise linear power supplies that replace the standard switching power supply of your Volumio devices, for a large reservoir of clean and stable power. The result is more realism, detail and dynamics in your music.
### Lineo5
-   One 5V/5A output, to power one device.
-   Compatible with Rivo, Rivo+, Preciso, Primo V2 and Primo Plus.
-   Supports 110V and 220V mains with a selection switch, and comes with 4 AC cables (EU, US, UK, AU/NZ).
### Lineo5 Duo
-   Two independent 5V/4A outputs, to power two devices at the same time with a single power supply, such as Rivo+ and Preciso.
-   Compatible with Rivo, Rivo+, Preciso, Primo V2, Primo V3 and Primo Plus.
-   Supports 110V and 230V mains (50/60Hz).
### Which one is right for you?
-   Choose Lineo5 to upgrade a single device, such as your Rivo or Primo.
-   Choose Lineo5 Duo if you have, or plan to have, a streamer and a DAC, for example Rivo+ and Preciso: one elegant power supply for your whole digital chain.
> **Warning:** Lineo5 and Lineo5 Duo are not compatible with Integro and Motivo. Before powering on, make sure the voltage selector matches your mains voltage.
Full specifications and current prices: [Lineo5](https://shop.volumio.com/product/lineo5/) and [Lineo5 Duo](https://shop.volumio.com/product/lineo5-duo/).
