Lineo5 and Lineo5 Duo are low-noise linear power supplies that replace the standard switching power supply of your Volumio devices, for a large reservoir of clean and stable power. The result is more realism, detail and dynamics in your music.
Lineo5
One 5V/5A output, to power one device.
Compatible with Rivo, Rivo+, Preciso, Primo V2 and Primo Plus.
Supports 110V and 220V mains with a selection switch, and comes with 4 AC cables (EU, US, UK, AU/NZ).
Lineo5 Duo
Two independent 5V/4A outputs, to power two devices at the same time with a single power supply, such as Rivo+ and Preciso.
Compatible with Rivo, Rivo+, Preciso, Primo V2, Primo V3 and Primo Plus.
Supports 110V and 230V mains (50/60Hz).
Which one is right for you?
Choose Lineo5 to upgrade a single device, such as your Rivo or Primo.
Choose Lineo5 Duo if you have, or plan to have, a streamer and a DAC, for example Rivo+ and Preciso: one elegant power supply for your whole digital chain.
Full specifications and current prices: Lineo5 and Lineo5 Duo.
