title: "What is Preciso and why choose it?"
description: ""
url: https://help.volumio.com/en/articles/159-what-is-preciso-and-why-choose-it
collection: "FAQ"
updated: 2026-10-20
language: en
# What is Preciso and why choose it?
Preciso is Volumio's high-precision DAC: the ultimate expression of everything we've learned in crafting award-winning digital audio players, designed to deliver the purest, most precise sound without breaking the bank.
### Why Preciso
-   Hyper-symmetrical dual mono design: 2 ESS ES9039Q2M DACs in mirrored, isolated circuits for maximum channel separation and the lowest crosstalk.
-   Measured THD+N of -122.5 dB, at the threshold of today's most sensitive audio test equipment.
-   Dual linear power supply with separate regulation for analog and digital paths, a precision MEMS clock and premium opamps.
-   8 digital filters and NOS mode, to tailor the sound to your taste.
-   Built-in Hardware Gain Control with precise 0.5 dB step adjustment, from 0 dB to -99 dB, removing the need for an external preamp. Preciso can also be used as a preamp for direct integration with power amplifiers.
### Connections
-   Inputs: USB and I2S over HDMI up to PCM 768 kHz/32-bit and DSD512, optical and coaxial up to PCM 192 kHz/24-bit.
-   Outputs: balanced XLR (4 Vrms) and unbalanced RCA (2 Vrms), to your amplifier, power amplifier or active speakers.
-   12V trigger input and output, to switch your whole system on and off together.
### The perfect partner
Paired with Rivo+ via I2S, or with Rivo via USB, Preciso completes a fully optimized Volumio digital chain. It also works with any other streamer, computer or digital source. Add Remoto to control volume, inputs, playback and DAC filters from your listening chair, and Lineo5 Duo to power both Preciso and your streamer with clean, linear power.
Full specifications and current price: [Preciso](https://shop.volumio.com/product/preciso/).
