What's the difference between Rivo and Rivo+?
Rivo and Rivo+ are both pure digital streamers (digital transports): they stream your music in the highest quality to your DAC, amplifier or active speakers with a digital input. Both are designed and made in Florence, include all Volumio Premium features at no additional cost and are Roon Ready.
Rivo+ builds on the award-winning Rivo (EISA Best Digital Player 2023-2024) with a set of upgrades for the most demanding systems.
What Rivo+ adds
  • I2S/DSD over HDMI output: up to PCM 768 kHz/32-bit and DSD512, with adjustable pinout, for high-end DACs with an I2S input such as Volumio Preciso.
  • A dedicated ASIC that generates the S/PDIF and AES/EBU signals, offloading this task from the CPU for cleaner digital outputs, now also with DSD64 via DoP.
  • Upgraded MEMS clocks for lower jitter and higher stability, including on the USB DAC output.
  • A 12V trigger output to switch your other components on and off together with Rivo+.
What they have in common
  • USB DAC output up to PCM 1536 kHz/32-bit and DSD1024 (with multiroom disabled).
  • S/PDIF coaxial and AES/EBU outputs up to PCM 192 kHz/24-bit.
  • Same platform: quad core 1.9 GHz CPU, 2 GB RAM, 16 GB storage, Gigabit Ethernet, dual-band Wi-Fi, Bluetooth 5.0 and HDMI output for the Volumio interface up to 4K.
  • TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, Spotify Connect, AirPlay, UPnP/DLNA, multiroom and your local or network music library.
Which one is right for you?
  • Choose Rivo if your DAC or amplifier connects via USB, S/PDIF or AES/EBU: you get the same award-winning sound and the full Volumio experience.
  • Choose Rivo+ if your DAC has an I2S input, if you want the cleanest S/PDIF and AES/EBU outputs, or if you want to switch your system on and off with the 12V trigger. Paired with Preciso, it forms a complete Volumio digital chain.
Rivo is also available in a Black Edition with an upcycled leather front panel, and Rivo+ in a Special Edition with a brown leather finish.
Full specifications and current prices: Rivo and Rivo+.
