title: "What is the Digital inputs switch in Sources?"
description: ""
url: https://help.volumio.com/en/articles/151-what-is-the-digital-inputs-switch-in-sources
collection: "FAQ"
updated: 2026-11-05
language: en
# What is the Digital inputs switch in Sources?
The `Digital inputs` switch in `Sources` enables the Premium Digital Input feature. It lets you play audio from an external USB device with an audio input through Volumio.
For example, with a USB audio interface with a phono input, you can connect a turntable, select it as a source and send it to your DAC through Volumio.
> **Warning:** Without a USB input device connected, the switch has no effect. You can turn it off if you don't need this feature.
