title: "Can I update my Raspberry Pi from Volumio 3 to Volumio 4 over the air?"
description: ""
url: https://help.volumio.com/en/articles/150-can-i-update-my-raspberry-pi-from-volumio-3-to-volumio-4-over-the-air
collection: "FAQ"
updated: 2026-10-20
language: en
# Can I update my Raspberry Pi from Volumio 3 to Volumio 4 over the air?
No. On Raspberry Pi it's not possible to update from Volumio 3 to Volumio 4 over the air: you need to write a new Volumio 4 image to your SD card.
Volumio 4 is a fundamental change from Volumio 3, and a fresh installation is the only way to make sure everything works correctly.
> **Warning:** A fresh installation resets all settings, so you'll need to configure your device again afterwards.
