title: "The volume of Preciso is lower on USB than on coaxial. What should I do?"
description: ""
url: https://help.volumio.com/en/articles/148-the-volume-of-preciso-is-lower-on-usb-than-on-coaxial-what-should-i-do
collection: "Issues & solutions"
updated: 2026-10-20
language: en
# The volume of Preciso is lower on USB than on coaxial. What should I do?
If the volume of Preciso is much lower on the USB input than on the coaxial input, check the startup volume setting in Volumio.
1.  Go to `Settings` → `Playback Options` → `Volume Options`.
2.  Set `Default Startup Volume` to 100 and save.
3.  Then adjust the listening volume with the right knob of Preciso.
