title: "How to connect Preciso to Rivo+?"
description: ""
url: https://help.volumio.com/en/articles/138-how-to-connect-preciso-to-rivo
collection: "FAQ"
updated: 2026-10-20
language: en
# How to connect Preciso to Rivo+?
Preciso can be connected to Rivo+ via USB or via I2S over HDMI. Both connections support up to PCM 768 kHz/32-bit and DSD512.
### Connection via USB
1.  Connect the USB output of Rivo+ to the USB input of Preciso.
2.  Power on Preciso first, then Rivo+.
3.  Select the USB input on Preciso with the left knob.
4.  In Volumio go to `Settings` → `Playback Options` → `Output Device` and select Preciso, then save.
### Connection via I2S
1.  Connect the I2S (HDMI) output of Rivo+ to the I2S input of Preciso with a standard HDMI cable, as short as possible.
3.  Select the I2S input on Preciso with the left knob.
4.  In Volumio go to `Settings` → `Playback Options` → `Output Device` and select `S/PDIF + AES/EBU + I2S`, then save.
> **Warning:** Preciso is already configured to work with Rivo+ via I2S, so no I2S mode or channel setting is needed on the DAC. Only one output can be active at a time: to switch between USB and I2S, change the output device in the Volumio app.
