title: "Which connector does the Lineo5 power cable use?"
description: ""
url: https://help.volumio.com/en/articles/137-which-connector-does-the-lineo5-power-cable-use
collection: "FAQ"
updated: 2026-10-26
language: en
# Which connector does the Lineo5 power cable use?
The Lineo5 and Lineo5 Duo use a 2-pin GX-16 connector on the power supply side, and a 5.5 × 2.1 mm DC plug on the device side.
If you need a longer cable, look for one with a 2-pin GX-16 connector and a 5.5 × 2.1 mm DC plug, and make sure the polarity matches the original cable.
> **Warning:** Some older product documentation mentions a GX-12 connector. The correct connector is GX-16.
