title: "How do I enable SSH connection?"
description: ""
url: https://help.volumio.com/en/articles/13-how-do-i-enable-ssh-connection
collection: "FAQ"
updated: 2026-10-25
language: en
# How do I enable SSH connection?
SSH connection is exclusively dedicated for the developer’s access to Volumio OS via command-line. It is disabled as default (recommended for security reasons). Enable it only if required, for remote support or for saving a log link.
To enable SSH:
Navigate to [http://volumio.local/dev](https://volumio.local/dev) or [http://yourvolumioip/dev](https://yourvolumioip/dev), where `volumio` / `yourvolumioip` is the actual name / IP address of your device eg. `Rivo` or `192.168.1.54`.
Find the SSH section, and click `ENABLE`. From now on your SSH will be permanently enabled. To disable SSH again, click `DISABLE`.
